07-25-2019
12:36
16:21
AndreaFitbit
07-25-2019
12:36
16:21
AndreaFitbit
I just bought a new versa and I am not able to control the volume with my watch ! I found out that was an issue with fitbit versa but I am wondering if there is fix for it. I restarted then removed airpods and then paired again but no luck !
Thanks,
07-26-2019 16:39
07-26-2019 16:39
Welcome to the forums @FirasB. I'll be happy to assist you with your Versa and Airpods volume control inquiry. Thank you for mentioning the steps you have followed in order to resolve this situation.
At this time, you won't be able to control the volume on Apple Airpods. You can vote for this suggestion Make versa volume controls work for AirPods.
Keep on visiting the forums.
Best Answer12-25-2019 11:40
12-25-2019 11:40
I found that on my Versa with the latest firmware release, Airpods volume control worked OK. However, on my new Versa 2, the volume control works but the maximum volume is very low. This is unfortunate and the Airpods are barely usable. Fitbit, please comment on a fix for this issue.
