07-31-2019 05:05
07-31-2019 05:05
Is there a way for me to increase the intensity of the vibration or add a sounder to the alarm feature?
Best Answer07-31-2019 07:22
07-31-2019 07:22
Sound is not an option as no current fitbit model incorporates a speaker. There is though a setting that can change the vibration strength. Swipe left from the clock until you see the settings app. Select that and then scroll up until you see the vibration setting which can be set to "normal" or "strong". I think this affects all vibrations including alarms but I don't use the alarm feature so am not 100% certain.
