09-15-2019 21:28
09-15-2019 21:28
Has anyone figured out an option for the always on clock/screen to be of our own choosing?
I MUST have the seconds showing and that appears not to be an option.
I can also only set it to stay on my chosen face for 1 minute, nothing longer? Why no 2 or 5 minute option?
Let me know if you have discovered a workaround! 😄
09-15-2019 21:35
09-15-2019 21:35
You are correct - no seconds with always-on clock, and 60 seconds max for screen time-out, I suppose for battery life. You can set the timer, though I realize that might not meet your needs.
Best Answer09-15-2019 21:35
09-15-2019 21:35
Best Answer09-15-2019 21:40
09-15-2019 21:40
Better than nothing, but not what I was after for my $200. 😞
Best Answer09-15-2019 22:09
09-15-2019 22:09
The always on clock faces are designed for power saving, taking advantage of how AMOLED screens work (black pixels being completely off), the more black on the screen, the more efficient the clock face is.
Best Answer09-15-2019 23:26
09-15-2019 23:26
Naturally, but I would have preferred an option that matched the needs of my profession.
Best Answer09-15-2019 23:31
09-15-2019 23:31
Best Answer09-30-2019 10:17
09-30-2019 10:17
That's a stop-gap for now but hopefully they update it to add longer options and screen options! 🙂
