11-25-2018 14:05
11-25-2018 14:05
Has anyone else experienced the app freezing after anything since downloading the versa? I can't change the clock face because it freezes each time. Also, how do I get rid of apps I don't want and download new ones it freezes each time I try to download a new app but there is no option for deleting the apps on there.
Best Answer11-25-2018 15:18
11-25-2018 15:18
open the app, tap the icon for the Versa and then tap apps. Tap the app you want to uninstall. Note, not all apps can be uninstalled.
Best Answer11-26-2018 12:13
11-26-2018 12:13
Hey @Laceyl91, welcome aboard! As @SunsetRunner says, there are some apps that can't be uninstalled from your Versa, as they come by default and can't be removed. Now if the Versa is freezing every time you try to open an app or change the clock faces, why don't you tried to restart your Versa? Just follow these instructions to do so.
Let me know how it goes!
