I am trying to add additional workouts from coach to my Versa and part of the "how to" says to check that you have the latest app version of coach. Do to this it says go into account settings then into Apps. But I have no Apps option under account settings only a "compatible apps" section......
Best AnswerHi, go to Apps within your Fitbit app, and not your account, and press first my Apps and see if the app is in the list. If yes, there should be a settings icon on the right side of your app to adjust the app. If it's not is the my Apps list, go to All Apps and type in the search bar the Apps you want to install. When a typed in app does not show up, it's not compatible with Fitbit. Good luck!
Best Answerit is not your account settings, but your Versa settings @Mcsasquatch before you can get to the Apps list, you will need to tap the versa in the top right.
Now tap Apps
If you do not see Coach under My Apps tap All Apps
Rope Coach into the search bar and enter, tap on the Coach App
Tap install
You will need Wifi to install so the Versa needs to be in it's charger and charging.
After installing, Afterwords Coach will show up under My Apps.
