07-18-2018 13:29
07-18-2018 13:29
Hello all,
I was wondering how else I can add my student ID to my Fitbit Versa. If you are anything like me you forget things, and I have heard of having a screenshot of it in a 3rd party app, but how would I get the brightness up? Any ideas?
Best Answer07-18-2018 13:48 - edited 07-18-2018 13:49
Which mobile operating system are you using? If Android, have you tried something like this app to scan the barcode and generate a number from it. You could then enter the number into the app on the Versa.
I would imagine there is something similar if you are using iOS instead of Android.
07-18-2018 13:36
07-18-2018 13:36
Have you tried the Barcodes app by Terry in the fitbit app gallery?
07-18-2018 13:38
07-18-2018 13:38
Yes I have that app on my fitbit, the thing is that it doesn't have a barcode under it.
Best Answer07-18-2018 13:41
07-18-2018 13:41
