10-25-2018 18:00
10-25-2018 18:00
Hello
on the Fitbit Versa, when you enter the Fitbit today my battery and date band has dropped from the top, and is now positioned between the daily step count (blue) and the active per hour section (red). Does anyone know how to replace the band to the top of the screen (above the step count).
Thanks in advance.
Jo
Best Answer10-25-2018 18:10 - edited 10-25-2018 18:13
Put your finger on and hold and after a couple of seconds you can move the position in the list. It is easy once you get the hang of it!
Woops I just tried what I said and that moved the contentsnofbthe list but not the date and battery. How about trying restarting your Versa a few times and see if that does it.
Another thought. Have you got the new update yet? I wonder if that changed the order (I havent got it yet)
Helen | Western Australia
10-25-2018 18:34
10-25-2018 18:34
Thanks. I’ll keep trying.
Best Answer10-25-2018 18:39
10-25-2018 18:39
I have the new update but that is it shifting the band either 🤷🏻:female_sign:
