08-13-2018 08:10
08-13-2018 08:10
I have had my Versa for 2 months and the battery has always lasted 3 or 4 days. I updated it last week per tech supports recommendation for an issue I was having - now my battery will not last 1 day. It will be at 100% in the morning and almost dead by 4 or 5pm. No settings have changed and have tried resetting. Help!
08-13-2018 08:52
08-13-2018 08:52
Sounds like it may be time to contact support.
08-13-2018 10:16
08-13-2018 10:16
I am experiencing the same thing with my Versa starting very recently. I've had it off the charger for 5 hours and it's already lost 40% of its battery. Reset the watch, turned off sync and notifications, removed all alarms. I just had to go about re-adding the watch to the Fitbit app 2-3 times the past week because it stops syncing every few days, now this.
08-13-2018 12:52
08-13-2018 12:52
Having the same issue. I think its after the last update. Lost more than 50% in less than 24 hours.
08-13-2018 13:47
08-13-2018 13:47
It's been 9 hours now and my Versa is completely dead. I hope there's a response and update coming soon because otherwise I will assume my Versa is defective and have support send me a replacement.
08-13-2018 15:08
08-13-2018 15:08
Same here! So frustrating! I have already had to co tact support 2 other times for completely different issues... I love my versa but starting to think it's more of a pain than a help.
08-13-2018 22:47
08-13-2018 22:47
Is anyone now also having trouble with swiping? My Versa is also now having an issue recognizing swipes. Sometimes it doesn't detect at all, other times it thinks it's a half swipe and won't change screens, and finally, it sometimes registers swipes as taps.
08-14-2018 06:31
08-14-2018 06:31
Going through it with Support right now and it's a mess. I actually completely factory reset the Versa last night, took it off the charger fill at 1am and at 9am when I awoke, it was at 13%. So they want me to try these battery optimization techniques. I don't care the settings, under NO circumstances should this device, which is supposed to have 4+ days battery, be draining to empty in less than 12 hours. Anyway, it looks like it needs replacing and I will try to do it through Square trade since it reads like from others thaytFitbit takes over 2 weeks to send a replacement.
08-14-2018 06:37
08-14-2018 06:37
Did they tell you to factory reset? Bernt hi king about trying that too.
08-14-2018 08:48 - edited 08-14-2018 08:49
No, I tried it on my own because I was frustrated by the situation and looking for a way to resolve it.
Their current steps are for me to:
1. Disable features which may reduce battery as detailed on their website. This includes disabling the heart rate, disabling screen to wake, disabling notifications, removing all alarms, and turning off Reminders to Move.
2. Charge Versa to full battery.
3. Sync Versa 5-6 times throughout the day.
4. Wear the tracker until it is fully depleted.
They can look into your account and see the battery history, so they definitely have confirmation that it is not performing up to standards.
08-14-2018 09:52
08-14-2018 09:52
I am also facing battery drain after the recent update. Battery does not last not more than 2 days. It’s not performing well to give 4+ days battery life as stated by Fitbit. Expecting fix the issue
08-14-2018 10:04
08-14-2018 10:04
I had the exact same issue after the update, it became really laggy and drained the battery in less than a day, what I did today is that I removed the device, also removed it from by Bluetooth devices, and paired it again, then changed the watch face, it seems like it is solved now, I'm using around 1% every hour or so, that should deplete it by 25% today, so I should be good for the next 2 or 3 days, will have yet to see if it continues performing well or not.
08-14-2018 10:08 - edited 08-14-2018 10:12
Let’s see. I will try to do the same
08-14-2018 11:18
08-14-2018 11:18
I just did what you recommended, hopefully this helps! Thanks for the info!! 🙂
08-14-2018 11:58
08-14-2018 11:58
This is what support told me to do and well.
08-14-2018 17:13
08-14-2018 17:13
I recharged, unpaired and repaired, turned off notifications and other alerts and it seems to be doing better now. I am still monitoring.
08-14-2018 19:06
08-14-2018 19:06
Same thing has happened to me! I’ve calked 4 times. Changed watch faces to a Fitbit one. Gaged battery life. Nothing is helping! I need it this weekend and Fitbit is stalling! I’m pissed!
08-14-2018 19:43
08-14-2018 19:43
I’ve been messaging with them through Twitter. Just gave them the update that even after the modifications, the battery died completely in 9 hours. Hopefully they’re going to send me a replacement now instead of making me ship this broken one back first at the slowest of shipping speeds. I’ll respond back when I hear, in case it may be easier for you than dealing over the phone.
08-14-2018 23:27
08-14-2018 23:27
Okay this is getting worse, I just checked the fitbit app and says that the last update was yesterday at 9 am in which I did what I commented on my previous post, currently 12am and cannot have my fitbit to connect to my phone anymore, not only that, it drained the battery to 49%... this is getting ridiculous, I'm getting tired of this thing, I don't know what else to try, it seems I can make it work doing the same process all over again but then it will go back to the same issue
08-15-2018 05:23
08-15-2018 05:23
Did what was recommended yesterday... surprise, surprise - NO HELP! Contacted support this morning - being told the exact same thing as everyone else ... this is bull!! Asked if we could somehow go back to the previous firmware version since that is what is causing the issue - nope! GRRRR 😡😡😡
