07-07-2023 11:42
07-07-2023 11:42
In the last three days my battery is draining really quickly. I emailed Fitbit. My versa 3 is 10 months old and they acknowledged my battery was draining but say that my watch warranty is done which I find appalling. These watches should last longer than a year. They offered no solution aside from buying another. What other brands are reliable and have better quality? My Fitbit versa before this one suddenly heated up while charging so hot I couldn’t even touch it. They replaced that one with the current one I have that isn’t even a year old and is dead in a day.
07-07-2023 17:22
07-07-2023 17:22
My Versa 3 is going on 3-years old, but suddenly this week it will not hold a charge, even after doing a factory reset.
The unit has worked great up to this recent issue.
The unit charges normally, but it is dead in a matter of a few hours.
07-07-2023 18:38
07-07-2023 18:38
This may sound weird but are you located in the US or in another country? I only had one replacement (due to an unrelated issue) which was well within the 1 year warranty and they replaced for free. I'm not sure how that works if your replacement needs a replacement (if that makes sense).
I've heard that the warranty outside the US is 2 years, if that makes a difference.
one cruise ship at a time!07-07-2023 20:51
07-07-2023 20:51
I’m in Canada. I’ve tried to look up warranty info and can’t find it anywhere.
07-07-2023 21:57
07-07-2023 21:57
Hi @Angtron - a replacement watch isn't covered by a full warranty, it follows the original warranty.
You can check in the watch Settings, about Versa 3 menu what activation date is shown.
If your original watch was getting hot it had internal damage, probably water damage.
A sudden change in battery life is an indication that a new problem has started on this watch too, possibly also water damage.
07-07-2023 22:01
07-08-2023 02:43 - edited 07-08-2023 02:45
Yes my problem began immediately after a minor water exposure (which the watch should more than tolerate). Sounds like I need to consider a replacement.
FYI, for $13.50 you can bump the standard 1-year warranty (2-years if in the EU) to 3-years via a 3rd-party warranty provide on Amazon.
https://www.fitbit.com/global/us/legal/returns-and-warranty
Thanks!
07-08-2023 04:25
07-08-2023 04:25
In less than 10 months? I don’t get my watch wet. I’m not a swimmer and I don’t shower with it on. I’m looking into other brands. We shouldn’t have to pay for a new watch once a year.
