12-09-2019 23:13
12-09-2019 23:13
Hi
Only purchased my Fitbit Versa limited edition in May this year and suddenly yesterday my battery is draining within 8hrs.
This now makes the watch pretty useless.
Haven’t changed anything. Is this common?
12-10-2019 01:31
12-10-2019 01:31
Hi @KatieP123 No, it is not common. Try restarting the watch several times and see if that helps. Also try a Factory Reset (Settings App on the watch and scroll down to About).
If you continue to have problems please co,e back here.
Helen | Western Australia
Best Answer12-12-2019 01:48
12-12-2019 01:48
The VERSA team deliberately put a bug on our devices that would affect the battery of first edition devices. I am experiencing the same post recent update. I have already disposed this device and switched back to apple watch.
Best Answer12-12-2019 02:10
12-12-2019 02:10
Hi @rajatparihar That is a rediculous statement. If you prefer Apple then by all means go back to it.
Best Answer12-12-2019 02:11
12-12-2019 02:11
"Try restarting the watch several times and see if that helps."
Yea the above statement is very logical right?
Best Answer12-12-2019 04:28
12-12-2019 04:28
Yep sure is. Sometimes it works with battery problems and sometimes it doesnt. It depends on the cause of the problem..
Best Answer12-12-2019 08:14
12-12-2019 08:14
Seems like you haven't updated your fitbit to a new version. Do it and then we will talk.
