As many others I experience problems with my Versa's battery. I have to charge it every day and it's very dissapointing. It worked fine in the beginning. Is it possible to have the battery changed?
I have turned off the autoscreen and brightness. If you have to turn off all functions, then you can just as well buy an ordinarie watch?
Hope there is a solution, I like my watch!
Hi @Lojne , did you update to version 70.7.14? If yes, this causes your battery problem. A lot of Versa users are complaining about this after the update. If your Versa is still under warranty, contact Customer Support. Regards kuzibri
