08-19-2024
11:23
07:11
08-19-2024
11:23
07:11
I currently have a versa 2 and have a freestyle libre 3 continuous glucose monitor (cgm). I am looking to find out the best fitbit to see my glucose level from my cgm on my fitbit.
@Joeversa2 I looked at your public profile, because your question is very similar to another post asking about Freestyle Libre and Fitbit. It sounds like you tried Glance in the past. I don't use a CGM, so it isn't clear to me if you can link your Freestyle Libre or not. Please try using Glance with your Freestyle. The Glance info says it will work with a Versa 4. If you can't link a Freestyle, then no Fitbit can help you. If you live in the EEA or UK, Fitbit can't help you at all. All third party clock faces were removed in the EEA and EU.
Laurie | Maryland
Best AnswerThanks. I purchased a versa 4 and will try the glance face again. I used the glance in the past with a dexcom and that worked. My insurance switched me to a freestyle libre 2 and it didn't work with that combination. I was told at the tine that i needed to upgrade my fitbit. I had just upgraded to a versa 2. I wasn't going to upgrade again at that point. I have now been upgraded to a libre 3 and am in a position to upgrade. I was just not sure if the versa 4 was the best one to use.
Best Answer@Joeversa2 This Glance Watchface page lists some of the data sources. Dexcom is obvious and listed. Freestyle isn't listed like Dexcom. If you can't get your Freestyle to link as a data source, then the Versa 4 can't help you.
Laurie | Maryland
