06-05-2018 13:45
06-05-2018 13:45
I brand new to fitbit, but bought it because my friends recommended it.
I have a Samsung S8 (v8.0.0) with a Versa FitBit (v2.72.1).
So I initially tried to use the Bike Activity, but I found that the roughly 4 mile trip only recorded at 20 meters!! The map itself is correct showing the entire route, but the distance is WAY off! This seems similar to this post except it is a different product.
I saw in many posts that they recommend using the Run Activity instead of the Bike to get a more accurate distance, but I then found that the Run Activity doesn't show a map (as described in this post)
And going through these forum posts I'm started to have a serious case of buyers remorse!
Has anyone else seen these problems?
How stable is Fitbit?
Thanks
Bob
06-06-2018 10:29
06-06-2018 10:29
@robert_w_brandt Welcome to the Fitbit Community! I hope you're doing well! Sorry to hear that your distance calculated during your bike and run activities. The Charge 2 does have a Connected GPS known issue that is being investigated. Several Fitbit app versions have improved the situation as you can read on one of the threads that you linked. Still it is suggested you turn off wifi when using this feature and be aware that tall buildings, trees and cloudy weather can affect the gps signal. You can try restarting your phone and your Versa before tracking a GPS activity by doing the following:
06-06-2018 10:29
06-06-2018 10:29
06-07-2018 11:13
06-07-2018 11:13
Thanks @AlvaroFitbit, that did the trick.
It took a few reboots and then this morning it wouldn't sync, but I think that was due to the fitbit website being down for maintenance.
Bob
06-07-2018 11:40
06-07-2018 11:40
@robert_w_brandt really happy to hear that this worked for you! Thank you so much for sharing this information. Regarding the sync issue you are totally correct, our servers were under maintenance and this affected directly the syncing capabilities. It should all be now back to normal.
I'll be around!
06-17-2018 03:04
06-17-2018 03:04
So this problem keeps happening. And after a good deal of troubleshooting ( FYI I'm a senior SysAdmin ) I found that if I have power-saving enabled on my phone I might have problems ( But it is inconsistent ). If I disable power-saving there are no problems.
This is not much of a problem during my normal workday as I can recharge my phone at work. But on weekends and vacations I need power-saving to get the phone through the day.
Even excluding the fitbit from power-saving does not help. 🙂
Just thought this might help others and hoping @AlvaroFitbit could forward this to engineering.
02-02-2019 09:29
02-02-2019 09:29
Are “run” and “bike” the only exercises that map a route? Not walk or hike???
