09-19-2018
00:53
04:53
AlejandraFitbit
09-19-2018
00:53
04:53
AlejandraFitbit
When I want to track a bike ride I usually launch it from my Versa watch itself. However, a few days ago I wanted to see the map while I was riding so I went to my Fitbit app (iOS): Exercise > Track > WTH?
When choosing to track an exercise there is only 3 options: Run, Walk, Hike... Why on Earth? So what I did is to track a "Walk" and categorize the exercise as "Bike" once I was done. Why I cannot directly track a biking ride from the app? Am I doing something wrong?
04:57
08:59
09-20-2018
04:57
08:59
A warm welcome to the Community @Eittam.
It's weird to hear that your biking exercise isn't listed in your exercise shortcuts and recommend doing the following from the Fitbit app:
I hope this helps, let me know the outcome. ![]()
09-20-2018 05:13
09-20-2018 05:13
Hi,
Thanks for your reply. Unfortunately your suggested solution does not work. I can add and delete exercises shortcuts to my Versa. That is ok. And I can track biking from there.
The issue is when I want to see the GPS map at the same time. I go to the app. Click track exercise. But the only available ones are Walk, Run and Hike. There seems to be no option to add more exercises to that list either. Please see the screenshots below:
09-20-2018 12:55 - edited 09-20-2018 13:01
Adding Bike to your Versa will allow the Versa to use the phones GPS and track your ride with the resulting map. True you can not see the map at the same time as the ride, but in many states using the watch while riding a bike is the same as using a cell phone while driving a car.
This is explained in your user manual, found under the help link below.
Your original ios question belongs in the iOS board and not the Versa hardware.board.
09-20-2018 21:23
09-20-2018 21:23
Sounds like Eittam is trying to pull up mobile run on the phone and get a bike option/map.
09-20-2018 23:33
09-20-2018 23:33
09-21-2018
10:46
08:27
09-21-2018
10:46
08:27
Thanks for the clarification @Eittam, @Rich_Laue and @MarkMM for stopping by.
Keep in mind that the MobileRun feature only have run, walk and hike as exercises. If you want to track your biking activity, you can do this by selecting the exercise directly from the Versa, using SmartTrack or by manually logging the activity.
Let me know if you need anything else. ![]()
