03-31-2020 12:12
03-31-2020 12:12
My screen went black yesterday. I’ve tried resetting it several times but nothing appears on the screen. It’s fully charged.
03-31-2020 13:09
03-31-2020 13:09
@Astella At this point I would try performing a factory reset (restoring versa to factory defaults) using the back button. This will wipe all data from your tracker so it would be good if you could sync it first. Before factory reset, make sure you have deleted versa your phone's Bluetooth settings (not Fitbit app).
After factory reset you will need to set up your versa again by adding a replacement device in your Fitbit mobile app. You can set up the watch back to the Fitbit account by following the instructions on this link: How do I set up my Fitbit device?
If you're not successful with the factory reset, I am afraid you will need to reach out to Customer Support to guide you through the next steps. Here's the link to Customer Support page.
03-31-2020 13:09
03-31-2020 13:09
