04-19-2020 13:44
04-19-2020 13:44
Hello all!
The bluetooth in my Versa has died. When i do a hard reset the bluetooth works for maybe a few seconds then cuts out. I'm wondering if there is a way to connect to the Versa over USB to my computer, enable Wi-Fi, then sync over that? Or maybe even just sync over USB?
Regards,
Communinja
04-19-2020 14:05
04-19-2020 14:05
I doubt your Versa bluetooth has really died. What specifically makes you say that?
And no, you cannot sync without it.
04-20-2020 05:16
04-20-2020 05:16
Hello @JohnnyRow ,
What specifically makes me say that the bluetooth has died is none of the devices I try can see my fitbit when scanning for bluetooth. If I do a hard reset on the fitbit (Holding the left button and bottom right button for 10 seconds) when the fitbit finishes booting my devices can see it briefly then it disappears. The fitbit app cannot see the fitbit long enough to do a sync.
Regards,
Communinja
Regards,
04-21-2020 13:23
04-21-2020 13:23
And now it won't charge or power on at all. Great.
