07-31-2019 19:07
07-31-2019 19:07
Hi,
I've lost just over 20kg (44lbs) in 6 months, now I weigh 76kg, female 165cm tall ... and the body fat content % isn't changing. I have the full version Versa. It's still saying I'm 47% body fat! Originally it said 53%, in January, then 47.9% in January, on January 31st it said, 47% and hasn't budged. Since then dates I have also been issued with a replacement Versa due to heating issue and the new Versa which I've had for about 4 months now is still logging the same fat % of 47 regardless of significant weight loss. I have a Samsung A5, the same phone since I purchased the original device.
Thanks for your reply in advance.
Pene
07-31-2019 21:03
07-31-2019 21:03
Hi, @Penelope11! I'm a little confused, do you have a Versa or an Aria? Aria is the scale, Versa is a wrist based step tracker.
MakMak | Community Council
Best Answer07-31-2019 21:16
07-31-2019 21:16
I have the Versa watch.
Best Answer07-31-2019 21:18
07-31-2019 21:18
When I log my weight onto the app, there is no change whilst in the beginning their was.
Best Answer07-31-2019 21:22
07-31-2019 21:22
If you're entering your weight manually, the only way the body fat would change is if you change it. The only way it updates automatically is if you're using a scale that calculates your body fat for you.
Best Answer07-31-2019 21:26
07-31-2019 21:26
That's confusing as it auto changed things in the beginning. Is fitbit looking at firmware update to calculate body fat when weight is entered manually?
Best Answer10-20-2020 04:02
10-20-2020 04:02
No a good feature if you must use a digital scale for body fat to read..
Auto Bmi. Would seem better to me. My Samsung health does bmi. automatically with manual entry.
