04-15-2020
13:07
11:05
DavideFitbit
04-15-2020
13:07
11:05
DavideFitbit
Hi please help just bought the Versa 2 thought it was a screen upgrade to the versa 1but it is so dim even on full brightness please help
Moderator edit: format
04-16-2020
00:24
11:06
DavideFitbit
04-16-2020
00:24
11:06
DavideFitbit
Not just me seeing the difference I suspect Fitbit changed things round as Versa original had dim medium bright and auto Versa 2 doesn't
02:08
11:06
DavideFitbit
04-16-2020
02:08
11:06
DavideFitbit
The main issue for me is not outside as it will get brighter in strong light it's when it's not so bright the brightest level is way down compared to original on max setting button Versa 2 even brightest setting is dull unless you shine a light to it . I'm sending both back it's not a fault with one as I bought two one each for us .
