01-08-2019 16:10
01-08-2019 16:10
The screen broke with a screen protector on it so I feel as if the glass is too fragile to be worn as a watch. I am looking for something else do, so I don't have to buy a whole new one.
Best Answer01-08-2019 16:50
01-08-2019 16:50
Hi, what happens when you take the protector off? Does you screen work than normally if not? When not, there are two possibilities:
1. Reboot your Versa by pressing and holding the left and right lower button together untill the Fitbit logo appears and release the buttons. If that does not work for you:
2. Call Customer Support about this issue
Best Answer01-08-2019 17:00
01-08-2019 17:00
The screen is fine, it is just cracked. It doesn't seem to sync right either
Best Answer01-08-2019 17:07
01-08-2019 17:07
Is your screen still usable? Seems to me it's not and now your stating that it's also not syncing right, I would advice you to see point 2 of my earlier post.
Best Answer01-08-2019 17:21
01-08-2019 17:21
Yes I already talked to them, absolutely nothing they can do, so they say.
