10-16-2020
09:13
10:42
10-16-2020
09:13
10:42
I just bought a Versa 2 and although it has a couple of calendar apps that I can download none are compatible with my IOS devices. Is fit bit going to come out with any newer & friendlier versions of a calendar that would be compatible with IOS?
Thanks for any info you can provide
Carolyn
10-17-2020 10:44 - edited 11-08-2023 15:17
Hi there @cast2, thanks for stopping by. I'm sorry to hear the Calendar Apps you were looking for seem not to be compatible with your phone. I understand where you're coming from.
For future references, with third party apps, note that Fitbit doesn't own or maintain third party integrations. It's up to the owner of the third party app to implement or update features for their app so in this case is recommendable to contact the third party developer to learn more about future implementations.
To contact the developer please open their app on the Fitbit App Gallery, scroll/swipe down and under "App Details" you will find the information.
If you want to have a calendar app, I'd suggest trying Agenda app that is already on your Versa 2. For more information, see: How do I set up and troubleshoot apps on my Fitbit device?
Let me know how it goes.
Best Answer10-27-2020 14:26
10-27-2020 14:26
HI Maree. I cannot get the Agenda app to work. I receive "No Events Today" I have seen many people have this problem. I have not seen anyone state "That Worked". I have even done a factory reset, as suggested by a moderator, that did not work either. Now I am reinstalling all my apps. I need to have a working calendar. This is a make or break my use of Fitbit. It seems so simple, a smart watch with a working calendar for business. What am I missing?
