03-09-2019 03:52
03-09-2019 03:52
Well I just bought an wore my Versa (set up and put on at 11PM bedtime) for the first time last night. Woke up, burned 4,000 calories in 5.5 hours of sleep!! Awesome! I guess I can eat 5,000 at least for breakfast if that is possible even. at 6' 1" 221, no way I burned that sleeping. How do I reset this thing? Not factory reset, just a simple cal reset. Or do I just return it?
03-09-2019 16:51
03-09-2019 16:51
Hi, just a simple reset is done by pressing and holding, multiple times in a row, the left and right lower buttons together untill you see the Fitbit logo and release the buttons. Good luck!!
03-10-2019 01:39
03-10-2019 01:39
Thank you, thank you! breezed the instruction booklet. Did not take the time to find it there, I am such a guy. Thank you again.
-John
