03-10-2019 01:52
03-10-2019 01:52
Over the last 2-3 days my Versa has suddenly started really draining the battery. I used to use about 25% in a day ever since I got it last May; now I'm using about 50% per day.
I have not changed any settings.
All-day sync is off (I had to block the Fitbit app from using mobile data because it was using way too much).
I have not updated the Firmware in a couple of months.
I've added no new apps.
My clock face has not updated.
I just charged it before bed as I always do, and then about Wednesday of last week I noticed it was using a lot more battery than usual. I hope it's not a sign of battery degredation...
03-10-2019 03:36
03-10-2019 03:36
Best Answer03-10-2019 04:29
03-10-2019 04:29
Yes, I've tried that. Every morning. It seems to help some, but a daily restart shouldn't have to be necessary.
Best Answer03-10-2019 05:27
03-10-2019 05:27
@gtg947h wrote:Yes, I've tried that. Every morning. It seems to help some, but a daily restart shouldn't have to be necessary.
I agree.
The only other thing I can really suggest would be the full factory reset. Some users have reported doing this has sorted their battery issues. I know it's not ideal but I can't think of anything else you haven't already covered. If you do attempt the reset I would suggest removing the device from your account and unpairing from your phones Bluetooth beforehand.
