07-21-2020 19:13
07-21-2020 19:13
hi! I just got my fitbit versa and I put in my weight and all that and I already have calories burned and I know it's the bmr. But can I turn that off so I have 0 calories? So I can only see calories i burned?
07-21-2020 19:23
07-21-2020 19:23
You cannot turn off BMR calories. They will reset to 0 at midnight.
Best Answer07-22-2020 07:21
07-22-2020 07:21
If you track an excercise (like a walk or something) it will show you calories burned just for the excercise.
Also, you can use the calorie tracker in the app (it shows calories burned each day) to see you calories. If you swipe down to before you started using Fitbit, it will still show calories. This is what Fitbit has calculated to be your BMR. You can just subtract that number from your calorie count whenever you check.
Best Answer07-22-2020 15:20
07-22-2020 15:20
@StephenLarsen wrote:If you track an excercise (like a walk or something) it will show you calories burned just for the excercise.
I agree with the 2nd paragraph above from @StephenLarsen , but not with the first one.
"If you track an excercise (like a walk or something) it will show you calories burned just for the excercise."
I tell my Fitbit in the exercise app that I am starting a walk (or any other type workout). Then I just sit still for an exact number of minutes, then end it. According to above, calories burned should be zero, but instead they show calories burned at my BMR rate. So the workout summary is including the BMR calories, though they probably are small compared to extra calories burned from exercise.
Best Answer07-22-2020 15:41
07-22-2020 15:41
You are probably right. I have seen the calories continue to track after a workout, but I assumed it was tracking cool down.
Hope this helps, Lacy!
Best Answer07-22-2020 15:55
07-22-2020 15:55
Yes, calories would still increase more than BMR after workout from higher heart rate while cooling down.
