I don't wear the watch at night. Every morning I start with 0 steps and anywhere from 600---2000 calories. I called support and they gave me the most ridiculous answer to why this is happening. I honestly think the guy was on drugs when he gave me his response.
It seems like the calories should be 0 just like steps when you start the day.
As well as tracking calories burned through activity your fitbit also tracks your BMR calories. These are the calories you burn just keeping your body alive (even when asleep). They are calculated from your profile settings for age, height, weight etc so you needn't be wearing your fitbit to get them. What you are seeing in the morning includes the total BMR calories burned since they reset at midnight and will vary depending on when you get up.
It's because it calculates them purely from your profile settings - it doesn't need to know what you were doing as they burn at a constant rate day and night. So, they will be the same whether you are wearing the fitbit or not.
Perhaps you might want to spend some time googling BMR calories if we are not able to convince you.
Unfortunately not. They reset to zero automatically at midnight and can't be manually reset. You also can't exclude the BMR calories from the total i.e. separate BMR and active calories.
There is a feature suggestion to change this that you might want to vote for:
