02-27-2021 11:17
02-27-2021 11:17
Hi,
Can anybody help? Trying to get my head around setting eating plan. I've set a food plan and am eating within my calorie allow but then when I click on my food for day, it says I'm approx 200 cals over budget - confused? Do I need to eat under the cals I've been allocated for day?
02-27-2021 15:48
02-27-2021 15:48
@Xenia83 It would help to understand the over/under tile. What Fitbit does is it takes your daily calorie deficit that you set and does a linear fit for the day. The day starts and ends at midnight. At midnight it looks for a deficit of 0, at noon it looks for a deficit of half what you set and then the full deficit at midnight. It calculates the over/under AT THE TIME YOU CHECK IT. However, since your intake and expenditure is not linear you will see some swings in the number. Checking before and after you log a meal or before and after you exercise will make a big difference in the numbers. Hope this helps.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
02-28-2021 00:45
02-28-2021 00:45
