Hi @Chris080106, welcome to the community.
I assume that you mean the ability to use quick reply or Alexa voice replies with Wechat. Which Phone/OS are you using? As both of these features are only available for Android users.
Best AnswerI'm using HUAWEI P30 PRO, after the watch receives the WeChat notification, there is no quick reply choice. Is it a setting problem?
Best AnswerAre you able to reply to the Wechat message from the notification that pops up on your phone? I believe some messaging apps don't have the option to reply from the notification (kik is one of them, I haven't used Wechat before), which is required to also be able to use quick replies on the Versa.
