07-27-2021
04:54
14:30
LizzyFitbit
07-27-2021
04:54
14:30
LizzyFitbit
Is there a way to reset a Fitbit Charge 3 by using the buttons?
Thanks
Moderator edit: subject for clarity and updated label
07-28-2021
04:15
10:31
07-28-2021
04:15
10:31
Hello @owensgroup. Welcome to the community forums!
Thank you very much for your question. I'd like to let you know that you can restart your Charge 3 from your wrist. You can open the settings app then tap on About > Reboot device.
Also, you can press and hold the button on your tracker for 8 seconds. Release the button. When you see a smile icon and the tracker vibrates, the tracker restarted. Note that this process should be performed when the tracker is plugged into the charging cable. For more information, I recommend visiting this help article: How do I restart my Fitbit device?
Hope this helps.
07-29-2021 11:50
07-29-2021 11:50
I forgot my pin on my Versa 2, is there a way to hard reset using the buttons?
Thanks
Best Answer07-29-2021 12:06
07-29-2021 12:06
@owensgroup which do you have - Charge 3 or Versa 2?
07-29-2021 12:21 - edited 07-29-2021 12:21
Versa 2, my mistake
07-29-2021 12:26
07-29-2021 12:26
I'll move this to the Versa 2 area for more relevant responses.
07-29-2021
14:27
10:31
07-29-2021
14:27
10:31
Hi @owensgroup. It's good to see you around. @Odyssey13 Thanks for stopping by to help our member.
@owensgroup Thanks for sharing more details and clarifying that you have a Versa 2. We have the restart and factory reset processes; however, since your watch is locked, my best recommendation is to get in touch with our Support team so they can provide you with further assistance and bring you back on track. Please click here to get connected with them via chat or phone.
Have a good day.
