09-06-2022
11:58
17:17
09-06-2022
11:58
17:17
Hi. I’m an professional reviewer and addicted to both Android and iOS.
is possible to easily switch the phone connected to my Fitbit on the fly whitout loosing settings history and other configured and saved stuff ?
09-07-2022 09:31
09-07-2022 09:31
@Franzfume Not Android vs IOS, but I've had the app on at least three different Android phones at the same time for many years. It works fine for me. Although at times it seems hard to sync on demand with one. At the end of the day, it all works out. Some here will not recommend having the app on multiple phones, but why not try it yourself? Worse case, you have to pick which one you like better?
20:19
07:13
09-07-2022
20:19
07:13
Hi @Franzfume - the watch can connect via Bluetooth to only one device at a time.
If you Logout of the app and turn off Bluetooth on the Android or iOS phone you are not using, and login to the app on the phone you want to use it should work for sure.
If you go to the home screen without closing the App, and click on the sync popup to get connected it sometimes helps speed up the process.
Best Answer09-07-2022 21:10
09-07-2022 21:10
@Guy_ Have you ever even tried it? I can move the currently syncing phone to another room. Go back and sync on whichever phone I want now. No logging out of app. No turning bluetooth off. Been doing it since 2016 with the Blaze. I never log out or turn blurtooth off. Whichever phone I'm currently carrying around will sync. Easy peasy. @Franzfume As I suggested, try it for yourself?
09-07-2022 23:35
09-07-2022 23:35
Oh thanks. It's easy !
