07-22-2020 11:01
07-22-2020 11:01
I cannot clear the "Data Not Cleared Sync And Try Again" message on my Fitbit Vera 2 Lite.
I have tried syncing it several times, and the message will not go away.
I have tried holding the left button in for 2 seconds then 8 seconds. That didn't work.
The message will not leave the screen. What do I do ?
Thanks.
07-22-2020 22:08
07-22-2020 22:08
Hello @KayakGal_87 are you getting a message of Clear Data or does the message say ,"Data not cleared"
If the latter, try a search, I find many solved threads.
07-23-2020 06:23
07-23-2020 06:23
I don't know what your reply is about.
It has nothing to do with the question I asked.
07-25-2020 13:30
07-25-2020 13:30
My answer has to do with the message of "data not clear" that occaisionly pops up on the various models of trackers.
Your question seemed to be about seeing a message of data not cleared.
The link to a search in my post above will bring up 20 threads of posts that have working solutions for the data not cleared.
If the data not clear message on the Versa has nothing to do with the "data not cleared" message you are seeing in the Versa, then I'm not sure how to answer.
