09-15-2018
17:32
05:06
AlejandraFitbit
09-15-2018
17:32
05:06
AlejandraFitbit
I am pretty close to returning this Versa due to incredible hassle with music. I am trying to download my own playlist, but there is insufficient space due to a Pandora playlist that refuses to be deleted. I keep getting the message "device storage is full." Help?
05:08
13:58
09-16-2018
05:08
13:58
It's great to see you around @EllenCF.
Please confirm you are doing the following to delete your playlists:
Hope to hear from you soon. ![]()
08:15
13:56
09-19-2018
08:15
13:56
Thanks for the update @EllenCF.
Have you tried to restart your watch? If you haven't, I recommend trying this by doing the following:
After the restart process, try the steps provided previously again.
Keep me posted. ![]()
Best AnswerI'm having the same issues with the Versa I bought for my wife. I really regret buying this device. I can't transfer my personal music because the device won't work with Windows 10 and the Pandora features aren't working either.
Best AnswerIf you go reinstall Pandora, click on the elipses and then "unlink pandora account", then it will remove the stations, then you can remove the Pandora app again. I had the same issue and it was driving me mad!
Nearly but thank you! (I did what you said but still showed half if my Fitbit Versa storage used up from Pandora music. After resetting Fitbit Versa, following previous comment instructions, I checked Fitbit app and storage used by Pandora was cleared out.) THANK YOU! 😁
I tried resetting my versa 2 watch. I also disconnected the pandora appt off my fitbit app. I cannot delete any playlist. Non of the tips you gave worked for me. My iPhone is also up to date. I do not understand what the problem is.
