07-09-2018
21:24
07:44
AlejandraFitbit
07-09-2018
21:24
07:44
AlejandraFitbit
Working on setting up new Versa. I have an old Fitbit and an old account. Both removed. Deleted and added again Fitbit. Still have a family Alta connected. Have Bluetooth built in. No Toggle came with Versa. Always gets stuck on "locating tracker". The Tracker shows a green check once in a while (2 times) but cannot sync. I have disconnected all Bluetooth connections on computer. Cell phone is off.
What am I doing wrong?
Thanks
07-10-2018 03:58
07-10-2018 03:58
What device are you connecting to when you try to set up? It definitely works best with a smart phone or tablet using the Fitbit app. Also, make sure you have charged the Versa from a wall socket and keep it plugged in during set-up.
Hilary | UK
Charge, Aria, iPhone 4s, Mac
If this answer is helpful, please vote for it and/or mark it as a solution.
07-10-2018 03:58
07-10-2018 03:58
Hilary | UK
07-10-2018 17:52
07-10-2018 17:52
Thank you. Why is this not clear in instructions? This worked. I guess Laptop is becoming less "useful".
Thank so much.
07-12-2018 07:45
07-12-2018 07:45
A warm welcome to the Forums @Kathleen3233 and @Hilary55 thanks for stopping by.
I am glad to see here that your setup issue has been resolved. If there is anything else we can help you with, do not hesitate to post it.
Happy stepping!
