03-16-2020 09:47
03-16-2020 09:47
Hello,
I tried a new clock face from the store - free.
My touchscreen worked once then it stopped working.
I changed it back - same issue.
So I can't swipe left or right anymore.
Suggestions?
Thanks,
Victor
Best Answer03-16-2020 09:57
03-16-2020 11:33
03-16-2020 11:33
Hello Carol!
I did try that. It still does not work.
What is the next step?
Thanks,
Victor
Best Answer03-16-2020 11:49
03-16-2020 11:49
Sorry it did not help, @Veepo. The only other thing I can suggest is a factory reset.
Hopefully this will work. Please let us know.
Best Answer03-22-2020 07:17
03-22-2020 07:17
Hi Carol,
here is the issue - I cannot get to the Factory Reset Menu option to reset it on the Versa Light - it requires the touch screen. There is only one button on it and it takes me to the quick options, once there - nothing on the touch screen works?
To factory reset your device: On your device, open the Settings app > About > Factory Reset or Clear User Data.
Hmm...What other steps can I take?
Thanks for your continuing assistance! #appreciated
Best Answer03-22-2020 09:28
03-22-2020 09:39
03-22-2020 09:39
Thanks!
I am not in a rush.
And yes, these are extraordinary times.
Stay well!
04-16-2020 06:38
04-16-2020 06:38
Carol-B,
I called support and they were able to get it reset but the problem happened again.
Another call - they decided to send me a new one.
Switching out he band was a bit of struggle.
My old Versa Lite has Smart Wake - this one no longer has the option - it is fully updates.
Does the option still exist?
Thanks,
Victor
04-16-2020 07:04
04-16-2020 07:04
Hi @Veepo - According to the Help pages, your new Versa Lite should still have the Smart Wake feature. You can try re-starting the device to see if that helps.
