01-12-2024
21:14
13:55
AndreaFitbit
01-12-2024
21:14
13:55
AndreaFitbit
How do I change temperature from Fahrenheit to Celcius. I changed it on the app, but does not change on my versa 2.
Welcome to the Fitbit Community, @Lance.s. Thanks for sharing your temperature units change query.
To change the units used for the temperature in the Weather app:
If the above doesn't do the trick, I'd recommend to try switching to a clock face that actually shows both units of measurements, Celsius and Fahrenheit, as not all clock faces will show the temperature in Celsius or Fahrenheit even when you've set it to be that way. For more information, see How do I change the clock face on my Fitbit device?
