Charging versa lite
I was just wondering is it normal for anyone that owns a versa lite after a full charge 100% once taken off charge and within a few seconds it goes to 99% it’s just happened again after I returned my old one for a new one?
4 REPLIES 4
Hi, this is totally normal. I do not own a Lite but a Versa but it does the same. You charge it untill it says 100% and after taking it out of the charger and putting it on your wrist, it  will say after a few minutes 99%. Again, this is absolutely normal and nothing to worrie about. My Versa, which does the same, lasts 5+ days on one charge.
Thank you for this.
I shall wait till tomorrow when I use it after a whole days charge to find out how long it will last....
Many Thanks again!
Sent from my iPhone
If it lasts normally and you think I really helped you with my answer, see my signature.
How much percentage do you think you use in a normal day?
Also with charging the watch would you recommend changing it throughout the night or only till it says fully charged?
Sent from my iPhone
