07-12-2019 21:03
07-12-2019 21:03
What is the best way to clean the back of a versa? I’m not meaning the band.
07-13-2019 04:45
07-13-2019 04:45
Hello @1-2 and a warm welcome. This Help article recommends using rubbing alcohol and a toothbrush to keep the charging contacts clean. With that in mind, I will clean mine with a lint free cloth slightly moistened with alcohol. Every now and then you should take the band off and clean the groove. The case and the edge of the band collect skin cell/sweat debris. Depending on how hard you work out, it can get icky in there. I use alcohol on a q-tip.
Laurie | Maryland
