01-21-2019 08:51
01-21-2019 08:51
The screen will not sync a new clock face. My previous one would not stop blinking like it was stuck. So I tried to pick out a new one but it will not sync and gives me an error. I do not get my versa wet so I did not short it or anything. What can I do to fix this. Thanks.
01-21-2019 09:02 - edited 01-21-2019 09:05
Hi, try restarting your Versa several times. If that does not solve the problem, install a clock face from Fitbit itself. The default one for the Versa is called "Layers". Withi the Fitbit app go to Clock Faces - All Clocks - Show all from Fitbit and choose Layers.
01-21-2019 13:40
01-21-2019 13:40
How do you restart it? I tried looking and I must be blind. I appreciate the help
Best Answer01-21-2019 13:47
01-21-2019 13:47
Click the link in my message, or else: press and hold the left and right lower buttons together untill you see the Fitbit logo and release the buttons. Other way is: go to the settings in your Versa, scroll down to Device info and scroll down to shutdown. Wait a few secs and press the Left button untill you see the Fitbit logo. Good luck!.
01-21-2019 15:11
01-21-2019 15:11
That worked THANKS!!!
01-02-2020 13:12
01-02-2020 13:12
Hi,
I have the same issue, and have reset the phone, and Versa 6 times, synced and still nothing. Im getting fed up now.
