04-02-2020 14:36
04-02-2020 14:36
My clock face has all of a sudden changed from showing steps to floors. I have re-selected the clock face I want with steps but it still shows floors. Any suggestions!
04-03-2020 13:27
04-03-2020 13:27
Your developer instructions about the face says double tap to change activities.
04-02-2020 16:32
04-02-2020 16:32
Lots of clock faces will change which data they show by simply tapping on the data you want changed. That's the way mine works.
04-02-2020 20:38
04-02-2020 20:38
cbwilsha.. Thanks for your reply. When you say you tap on the data you what, I assume you are referring to doing it on your iPhone. Which screen on your iPhone are you referring to?
Max99
04-03-2020 01:28
04-03-2020 01:28
Actually usually the tap is on the clockface itself. Can you please let us know what clockface it is?
04-03-2020 05:59
04-03-2020 05:59
As Giampaolo says I'm referring to the clock face. For example, where the floor data are shown on the clock face, tap it and it will probably change. Give it a try.
04-03-2020 08:44
04-03-2020 08:44
04-03-2020 13:27
04-03-2020 13:27
04-03-2020 13:34
04-03-2020 13:34
Fantastic.. It worked when I double tapped it. Thanks.
