My clock face on my Versa2, no matter which one I choose will change within seconds to a black and white clock. What is causing this?
Hi @SandyStambo , does this also happen when you install a CF developed by Fitbit itself? This is essential to know in order to be able to help you properly.
If you have enabled the "Always Disply On" mode, indeed your CF turn to Black and White after a certain time, which you have set in the display time settings. To get your coloured CF back, simply press the left button and it's back as you installed it. The turning to B&W mode is to preserve battery power. If you want to have your original CF all the time, then, as suggested by @werionae , turn off this mode.
Regards kuzibri
