06-29-2019 11:29
06-29-2019 11:29
I can only see the clock face (time/stats) on my Versa if I tap it hard several times or hit the button. It used to work when I moved my wrist but stopped.
06-29-2019 12:02
06-29-2019 12:02
Hold in left button a few seconds. Look for 'Screen Wake'. Tap to toggle on or off.
Best Answer06-29-2019 12:07
06-29-2019 12:07
Best Answer06-29-2019 12:08
06-29-2019 12:08
Thank you 😊
Best Answer06-29-2019 23:57
06-29-2019 23:57
Let's stop tapping the screen hard. It is a touch screen and only requires a light touch. Think of how you touch your phone.
Best Answer06-30-2019 06:28
06-30-2019 06:28
"Let's stop tapping the screen hard..." . If you think that was helpful you are so wrong. Someone else answered my question in an adult manner that solved my problem. Your answer was condescending.
Best Answer06-30-2019 10:41
06-30-2019 10:41
I'm very aware that someone else answered your question, I'm also a ware that the versa has a touch screen and does not depend on the accelerometer like some previous models do.
I was responding to "if I tap it hard", tapping hard often will make the finger slide a little across the screen, then the tap is not a tap anymore but a scroll.
My point is simply the harder a user taps the less likely the tap will work.
Best Answer06-30-2019 10:53
06-30-2019 10:53
I get it. My suggestion is to learn how to give an opinion without suggesting a person needs parental advice.
