01-19-2020
04:54
12:20
DavideFitbit
01-19-2020
04:54
12:20
DavideFitbit
Hi! Can i check and confirm if anyone know Versa 2 is compatible with Huawei Mate 30 Pro? Thanks!
Moderator edit: format
Hello @ZN16 and a warm welcome. The Mate 30 Pro is not on the list of compatible devices. That doesn't mean that the app won't work. You lust might not get full function. I recommend that you browse the Android forum and search using the name of your phone. I'm sure you will find some user experience comments.
Laurie | Maryland
