07-01-2018
10:17
08:45
AlvaroFitbit
07-01-2018
10:17
08:45
AlvaroFitbit
Hello
Please could you advise if the Huawei P 20 compatible with the Versa?
Thank you
07-01-2018 10:30
07-01-2018 10:30
phones and devices I have hooked my versa too with no problem.
1) alexa Dot and echo
2) Oontz angle 3 e99 blue tooth speaker (very Nice) $20.00
3) Iphone 7 Plus
4) iphone X
5) 2014 ford Escape Sync
6) Senso Blutooth Ear buds
7) alienware M17 R4 laptop
😎 HTC M8
I will update as i try new devices.
hope this helps
07-09-2018 03:51
07-09-2018 03:51
Thank you, I was looking at a Samsung s20 or the Huawei p 20
07-09-2018
06:01
08:52
AlvaroFitbit
07-09-2018
06:01
08:52
AlvaroFitbit
Here is the link to the Supported Devices List. Unfortunately I dont see either of those phones on there.
Helen | Western Australia
07-11-2018 12:30
07-11-2018 12:30
@MDB12 @Andrewl62 Welcome! It's nice to have you on board!
@MDB12 as @NellyG said your phone isn't listed as a supported device so I can't guarantee that it will or work without issues. Still not being on the list doesn't mean that you won't be able to sync your Versa with it. Do you already have the phone and the Versa. Have you tried syncing them? There are some users that have been able to use this phone with their Versa as you can see here and here.
@Andrewl62 This is a really helpful post, it does help know which devices have paired to your Versa's bluetooth.
Let me know how it goes!
Best Answer07-13-2018 05:48
07-13-2018 05:48
I have been testing me Bluetooth devices will be adding to my list shortly
Thanks
Best Answer07-19-2018 13:39
07-19-2018 13:39
has anyone connected the Versa to a Samsung Galaxy A8?
Best Answer10-13-2018 14:23
10-13-2018 14:23
I have both phone and versa and mine doesn't work Im gutted
11-13-2018 09:55
11-13-2018 09:55
@Nicolam2015 A warm welcome to our Community! Sorry to hear that you can't sync your Versa with your Samsung A8 phone and for the late reply. Your phone doesn't show as compatible but that doesn’t mean it won’t work it just means that it hasn’t been tested by our team. You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
Best Answer12-15-2018 04:35
12-15-2018 04:35
I have the motoral going 6play and my versa will not link up I am not a very happy camper right now
Best Answer12-29-2018 13:24
12-29-2018 13:24
Sorry to say this but you said Samsung A8 is not compatible phone for versa. But this phone is on your list of compatible phones. It should work therefore. Am I right in saying this. Thanks.
Best Answer12-29-2018 13:26
12-29-2018 13:26
Samsung a8 IS ON FITBITS COMPATIBLE LIST
Best Answer09-07-2019 22:58
09-07-2019 22:58
When is the Samsung Galaxy 10 going to be added as a supported device to many of the Fitbit device? My Charge 2 is freaking out. Now it is not holding a charge whatsoever and keeps flipping through screens often with any help. I know it's not a compatible device but it isn't compatible with the newer Fitbit of Versa either. Does anyone know when the Galaxy 10 will be compatible with any Fitbit device?
Best Answer09-08-2019 04:23
09-08-2019 04:23
12-27-2019 07:26
12-27-2019 07:26
Hi , I see that you stated you have the Galaxy A10e. Does it work good with your fitbit and do you have the versa 2 ? Can you receive your calls and text on your fitbit ?
Best Answer12-27-2019 08:10
12-27-2019 08:10
Best Answer12-27-2019 08:12
12-27-2019 08:12
Ok Great. I noticed you have the S10 and I wanted to see if it works with the Galaxy A10e ? Do you know anyone that have the A10e ?
12-27-2019 08:33
12-27-2019 08:33
Best Answer12-27-2019 08:49
12-27-2019 08:49
it's not listed on they list. But thanks for all your help
