Hi everyone,
I was hoping maybe one of you guys had the answer for me. I'm looking for a way to create my own custom workout routines so I can stop looking at my phone during my fitness sessions.
I'm following a personal fitness program and I'd love to check out the next workout from my Fitbit Versa instead of checking my phone every workout. Is there an app or work around available to get this done?
Thanks in advance!
05-08-2019
03:46
08:49
05-08-2019
03:46
08:49
@TranquilityX I'm not aware of this being something you can have on your Versa while simultaneously tracking a workout on your Versa.
However, there are some apps that might work. There's an app called Notes that you have to pay the developer (not Fitbit) for, but it can connect to your Google Drive account and it will display the latest documents created.
Noted is another app that you can have on your Versa. In their description, it says you can put your custom workout routine into the note. It's also an app you have to pay the developer for.
But I'm not sure how that works if you're tracking the workout on your wrist and then trying to open the app. I'm pretty sure you'd have to end the workout on your Versa in order to open a Notes app. So you have to decide what is more important: tracking your workout stats actively on your wrist or looking at your next workout in your routine instead.
Best of luck!
