When I try to set up my CC on the Wallet apt of my Versa 2 I get a warning that states "Screen Lock Required" Indicating I need to do a screen lock feature or a fingerprint feature.
Where does this come from?
Can I bypass this?
It is a security precaution to prevent other people from accessing your account should you lose the unit or it gets stolen. I don't believe there is a way to disable it.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
The PIN number being set up in the phone app is for the Wallet app on the Versa. The Versa will ask for the 4 digit PIN when you activate the Wallet app to use the card.
