05-12-2018 00:35
05-12-2018 00:35
Hi all, I need you help.
After half a day of reattempting to update my Versa for the latest update (and a lot of disappointment and wasted time later), I decided to reset my Fitbit Versa to factory settings.
However, this too failed, as the screen hung at the Reset Confirmation settings. I rebooted the watch, only to have it be in a continuous loop of "Data Not Cleared, Sync and Try Again" status.
Now it does not do anything. Anyone had this issue before? I have tried unpairing my phone from the device, but no effect on the watch.
Personally, Versa was quite good as a watch; but this is a real low in terms of user experience for me. The disappointment is real.
Thank you for any advice!
05-12-2018 19:55
05-12-2018 19:55
Found this in the Iconic Board. It worked for my Versa re #4 press 2 buttons:
Fitbit Ionic error message “Data not cleared. Sync and try again”
05-12-2018 19:55
05-12-2018 19:55
05-13-2018 20:24
05-13-2018 20:24
This just happened to me.
1. Go to bluetooth settings on your phone and forget or unpair your Versa
2. Turn off your bluetooth
3. Log out of the app and force stop it.
4. Turn off your phone then power it back on
5. Turn on bluetooth but don't touch anything else go straight to the app
6. Open the app and log back in
7. Try to set it up
These steps worked for me.
05-13-2018 21:47
05-13-2018 21:47
Hi Jenna,
Thank you for your help! My Fitbit Versa managed to connect after I removed its previous link to my smartphone and reset the connection.
The update worked shortly after the Versa reset as well.
As a reference and note to self, I found that it is good to reconnect the Fitbit to a WiFi connection before any update; my Fitbit seems to 'forget' the wifi connection now and then.
Cheers and thanks!
05-13-2018 21:49
05-13-2018 21:49
Hi rrr9142,
Thank you very much for your help!
Found that my main issue was not entirely disconnecting my Fitibit and resetting the link to my smartphone.
Cheers
08-08-2018 08:15
08-08-2018 08:15
Thank you, thank you!! This worked!! I have been fighting with my Versa regarding connecting the Weather app and the Nest app. I have tried about every other suggestion, this process worked!
10-16-2018 05:16
10-16-2018 05:16
Thanks for this ! I received my replacement Versa last week and could not clear the data sync error. Following these steps exactly worked !
11-13-2018 19:39
11-13-2018 19:39
Which steps above did you use?
I received a replacement Versa for one that had a bad battery. As soon as I plugged the new one in (and have done NOTHING with the phone or my old Versa), I get this error.
11-13-2018 20:04
11-13-2018 20:04
@theresamor Remove old Versa from your account (unlink) in the Fitbit mobile app. Remove (forget) old Versa from your phone's Bluetooth settings. Reboot your phone, open Fitbit mobile app and try setting up the new Versa.
11-14-2018 07:16
11-14-2018 07:16
Thank you! This worked perfectly for me after trying a few other ways to connect my fitbit versa.
11-16-2018 03:33
11-16-2018 03:33
RRR9142 this info worked after 2 days of **ahem**ing around your solution finally worked!
02-15-2019 16:12
02-15-2019 16:12
I tried this and it wont let me add a new device it just keeps taking me to a new screen help!
02-19-2019 21:17
02-19-2019 21:17
Hi @Jerritwdl
Are you adding a 2nd Versa or just adding a different tracker model
one cruise ship at a time!06-25-2019 09:08
06-25-2019 09:08
These steps worked great for me. Thanks!
08-25-2019 11:31
08-25-2019 11:31
How do you get the fitbit to reset?
09-29-2019 11:53
09-29-2019 11:53
Thanks your advice worked.
12-17-2019 03:52
12-17-2019 03:52
Thank you this worked!
12-28-2019 07:14
12-28-2019 07:14
what 2 buttins
12-28-2019 07:15
12-28-2019 07:15
were are all buttons
12-28-2019 07:48
12-28-2019 07:48
it does not have 3 buttons
