10-21-2021
09:26
09:27
BraulioFitbit
10-21-2021
09:26
09:27
BraulioFitbit
Hi i have a versa 2 lite and after charging it a message came up saying: Data not cleared ,sync and try again. I have tried all the options but to no avail....
Welcome, @miemers. It's great to see you around.
I appreciate the details shared and troubleshooting performed. This message will appear on your watch if a factory reset was performed, so I recommend you to follow the instructions from this help article: How do I set up my Fitbit device? to setup again your Versa Lite and remove this message.
By the way, I moved your post to the Versa smartwatches board to keep our Community organized.
Hope this helps.
Hi, @miemers.
It's been a pleasure to assist you. Hope this brings your Versa Lite back to life.
Have a nice day!
Hi, @miemers.
Thanks for the update. Since your Versa Lite is still unresponsive, I recommend you to contact our Support team by chat or calling them so they can check what's happening with your watch and look for a solution.
See you around.
