07-12-2022
20:16
17:47
07-12-2022
20:16
17:47
Has anyones’s Versa light watch die after this last update?
07-13-2022 10:31
07-13-2022 10:35
07-13-2022 10:35
Best Answer07-13-2022 10:45
07-13-2022 10:45
@Jenn31N- thanks, it could be that the factory reset kills the watch which is a known bug. Unfortunately it doesn't help.
You probably can verify that is the case just to be sure it's dead.
Wait till the battery is flat, press the button, it should show 0%, charge a few minutes, then press the button again and it will show nothing.
Placing the USB plug in a PC it should show present then not present repetitively.
