01-14-2021 05:05 - edited 01-14-2021 05:07
My versa 2 Will receive notifications but only after two hours or so. This is very annoying.
Last November I had to reinstall evertthing because i didn't receive any notifications. After 5! Hours the installation was completed. I don't want toen do it again.
Please help me with other options
01-14-2021 06:09
01-14-2021 06:09
As a first step, without installing anything its probably a good idea to do a restart if you haven't already.
Logout of Fitbit app [click profile photo, top left, scroll to bottom] Shut down watch [ Swipe left, Settings, at the bottom, About, at the bottom, Shutdown]
and wait for Logo and clock to appear] |
Secondly, if that procedure does not help and you are not using a standard Fitbit watch face currently then switch to one and see if it resolves the delay.
Hope this helps.
Best Answer01-14-2021 06:34
01-14-2021 06:34
Hi Guy, thanks for your reply. The notifications works now, but I stil don't see the incoming calls...
Best Answer01-14-2021 07:15
01-14-2021 07:15
Well done! Are you sure your watch is in sync?
In the phone Fitbit App Click on profile photo [top left] Device photo [middle left] Sync - See when last synced Try refresh by touching circle it should say "a moment ago" |
For calls you are correctly setup for incoming calls
In the phone Fitbit App Click on profile photo [top left] Device photo [middle left] Notifications And verify the top 4 items are correctly defined. Also App notifications and select any apps you want to hear from. |
Best Answer01-14-2021 07:20
01-14-2021 07:20
My watch is synced now. My watch reiceved all the notifications accept for the incoming calls. But that is nog very important. Thanks you very much for your help.
