12-04-2019
23:30
13:23
12-04-2019
23:30
13:23
I downloaded trial clock face retro 80, but now can not seem to delete it, just asking for me to pay to use it
Moderator edit: Format
12-05-2019 00:42
12-05-2019 00:42
Can you not just choose a different clock from the app?
12-07-2019 11:50
12-07-2019 11:50
@BIGCHILL Welcome to the Community. Thanks for the details mentioned.
Sorry for the delayed reply. In this case, you may want to contact the developer of the clock face and ask for further details. To do so:
- Go to your Fitbit app
- Tap on clock faces
- Choose the clock face you're using
- Tap to see the description and scroll down until you see "Contact Developer"
Thanks for your input @SteveH.
Best Answer12-12-2019 16:53
12-12-2019 16:53
I have the same problem. Did you get an answer? I just want to restore to the factory default but can't.
12-12-2019 16:54
12-12-2019 16:54
FitBit really need to do a better job supporting these basic things like deleting a clockface. One should be able to tap the face and choose a delete button. Poor implementation and documentation on Fitbit's part.
12-18-2019
12:39
10:49
12-18-2019
12:39
10:49
@Pat12345 Welcome to the Community. Thanks for the details mentioned.
Sorry for the delayed reply. In this case, you may want to perform a factory reset but keep in mind that this will delete all your stored data, personal information, credit/debit cards and saved settings.
Regarding your inquiry about deleting the clock face from your watch, you may want to post your idea in our Feature Suggestion board, those ideas are reviewed by our team and the status will change based in Fitbit's plans.
I'll be around if you have any additional questions.
Best Answer12-25-2019 07:38
12-25-2019 07:38
I stupidly clicked to select a different clock face and now I have no clock and just message asking payment. When you select a new clock face it does not confirm it is a purchase and goes thru the download - only then do you find out. You can uninstall it and ask the Fitbit app to 'forget' it but the original clock is gone and I am just left with a message asking for payment. My husband bought me this watch for xmas - now I can't use it.
12-26-2019
16:17
10:49
12-26-2019
16:17
10:49
@SunsetRunner It's nice to see you on the Community.
I would like you to try changing your clock face once again, this time try selecting a Fitbit clock face. If you're having issues, please try restarting it and change the clock face.
Best Answer01-17-2020 18:48
01-17-2020 18:48
Silvia, I find it hard to believe that in 2020, Fitbit doesn't know how to uninstall a clock face from a smart watch. We should not have to contact the developer to uninstall something available on your app store.
I've been trying to uninstall the clock face Ionic Reactor and have no way of doing so. Removing it from the saved clock faces does not remove it from the watch.
01-18-2020
16:44
10:48
01-18-2020
16:44
10:48
When you remove a clock face from your watch, it won't automatically change it. Please follow these tips to change your clock face.
Best Answer01-18-2020 17:18
01-18-2020 17:18
Silvia, as it turns out, this was due to a bug in the watch face and Fitbit sync. The developer resolved it.
But, as I said in my comment, simply switching the face wasn’t doing it for some reason. Hence the question.
16:04
10:48
01-21-2020
16:04
10:48
@SunsetRunner Thanks for getting back. I'm glad to hear that you contacted the developer and it was resolved.
Best Answer01-25-2020 19:04
01-25-2020 19:04
I selected and loaded a new clock face which worked. BUT now I have that and another digital clockface as well. how do I get rid of that one? Really if there was another good fitbit type product I'd throw this Versa 2 in my dog's water bowl.
10-02-2021 06:15
10-02-2021 06:15
So you're saying that I can only download 5 clock faces on this watch (according to the watch) and as a user I can never delete those? So when I'm done I'm done? Is that not a massive issue to y'all?
11-29-2021 08:48
11-29-2021 08:48
I wish I knew this. I guess we have to factory reset it.
Best Answer12-23-2021 15:16
12-23-2021 15:16
I've tried removing the clock face, but there's no "Remove" button. I've removed all the other clock faces and did a factory reset of the fitbit (mine is a Versa 3). Not only can I NOT remove the purchased clock face, I can't add any additional clock faces from the app, even though they show up in the app. My versa 3 only displays the purchased clock face.
12-23-2021 22:26
12-23-2021 22:26
Hi @Swhite1 - the main issue is you can't remove the active clock face from the App.
If you can, on the watch, swipe to the left and click Clocks and select another clock face, if there is one, and sync with the Fitbit App. This will make another clock face the active one.
Then in the Fitbit App choose, but don't select, the one you want to delete and scroll to the bottom and click on Remove clock face.
If the watch is synced it may also be possible in the Fitbit App to select an existing clock face [or install one] and then choose, but don't select, the one you want to delete and click on Remove clock face.
Sometimes when a clock face is frozen it is not possible to load or change clocks from the Fitbit App but it should still be possible on the watch to switch clock face, if there is one
Note: For an up-to-date Versa 3 long pressing the clock face should invoke Clock switching.
Best Answer12-24-2021 13:19
12-24-2021 13:19
Try this YouTube vid: https://youtu.be/WkfxgkwqOlo
Best Answer12-24-2021 13:20
12-24-2021 13:20
Try this YouTube Vid, to remove the current face, change to another then follow this vid: https://youtu.be/WkfxgkwqOlo
06-24-2022 11:23
06-24-2022 11:23
YES, it is!!! Going crazy trying to delete the ones I don’t want and have not found an answer yet. I would have been a LOT more picky if I’d known this..l <ugh>
