12-09-2019
13:03
11:03
RicardoFitbit
12-09-2019
13:03
11:03
RicardoFitbit
My versa lite also has the same problem - it is constantly freezing, I have only had this for 3 months, in fact I just threw away the packaging because I thought everything was good and then this freezing issue started!
Moderator edit: updated subject for clarity and label
11:02
09:33
12-10-2019
11:02
09:33
Hello @Carrie1964, welcome to the Community Forums!
Thanks for bringing this to my attention, certainly your device isn't working as the way it was designed. To better assist you with this, can you please let me know when was the first time you experienced this freezing concern and how many times since then? If you haven't already done so, please try restarting your device following the next steps:
Let me know if you have any additional questions.
Best Answer12-10-2019 11:25
12-10-2019 11:25
Best Answer12-10-2019 11:27
12-10-2019 11:27
It's been happening for the last 2 to 3 weeks - off an on. The only way i can get it to work -sometimes - is to reset it as described in your reply; unfortunately it just keeps on freezing. Sometimes it lasts for 1 minute and then freezes other times it has lasted a day, but typically it only lasts half a day. I did the update a few days ago and was hoping that would have helped, but it did not help at all. I will try the "shutdown" provided I can access the settings on the watch without the watch freezing up on me, I've tried twice already to access it and it freezes, even right after resetting the watch
17:14
09:34
12-13-2019
17:14
09:34
Thanks for your reply and the details that were shared on it @Carrie1964, sorry for the delayed response.
Since the restart process didn't work, please try the following steps to perform a factory reset on your device:
Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Keep me posted.
Best Answer12-18-2019 07:57
12-18-2019 07:57
Ricardo - this is not going well at all. I did the factory reset and now i can not get it to go through the set up phase, all it wants to do is update. I've tried several times to update, but it just won't complete it. I am at a loss as to what I should do next. Can I return this? I haven't been able to use it in a long time.
