04-23-2020 05:32
04-23-2020 05:32
Hi all,
Hope everyone is staying safe .
Has there been any update of fixes for devices that are locked and unable to connect to a new account or previous account , I foolishly removed the device from the account when I was giving into a family member without realizing it was blocked when trying to change the band.
I seen most have to send product back but not sure if feasible in current times. Any fixes, ive tried 3 button hard reset but hasnt been successful. any workarounds?
KJ
04-23-2020 10:11
04-23-2020 10:11
Oops, all you had to do was unlock your tracker, swipe to settings then factory reset. This can be done while connected or not connected to a Fitbit account.
Now we have to do the factory reset the hard way @killjester
Fitbit OS hardware reset.
On the watch, hold all three buttons for about twelve seconds. This will trigger the 2-button hardware restart after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, whilst continuing to hold the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
Best Answer04-23-2020 10:39
04-23-2020 10:39
Best Answer04-23-2020 11:06 - edited 04-23-2020 11:15
Since your tracker is locked, you only have one state when the three buttons can be pressed.
As for how long to hold? hold the three buttons until the tracker restarts. The instructions say about 8 seconds.
As for holding the 2 buttons? Until you feel the vibration.
Best Answer04-23-2020 11:14
04-23-2020 11:14
